'01 Montero XLS (steering wheel squeak)???
Old Apr 30, 2007 | 05:10 PM
ken lally's Avatar
Default '01 Montero XLS (steering wheel squeak)???
Hello all, 97K miles now, when I turn my steering wheel at slow speeds, I hear a squeak, almost like rubber rubbing against rubber.... is there somebushing orsomethingjust behind the wheel? Will asquirt ofsome lube make it dissapear?
Thanks in advance!!
Old Apr 30, 2007 | 05:23 PM
carlover626's Avatar
Default RE: '01 Montero XLS (steering wheel squeak)???
I have this occuring on my 02 Sport as well, maybe an easy fix?
Old Apr 30, 2007 | 08:27 PM
Manybrews's Avatar
its the rubber boot at the firewall, in which the steering shaft goes through.
push it down a bit, and spray the shaft with some WD-40 (or the like).
Old May 3, 2007 | 10:30 AM
ken lally's Avatar
I fugured as much- I'll give it a try, thanks Manybrews!
Old May 9, 2007 | 01:27 PM
ken lally's Avatar
Yep! That fixed it! Sprayed some oil around the boot and it took care of the problem - wow cheap fix, thanks!
shildog
Sep 14, 2014 03:17 PM
Montezuma
Nov 26, 2012 03:35 PM
Nubiebubie_GSX
Oct 27, 2006 09:18 PM
Eclipsor
Oct 15, 2006 09:51 PM
brg606
Dec 28, 2005 11:43 PM
