02 Montero XLS
Im having some issues. I bought this vehicle in March of 2012 and with in a month had to put 2 new wheel bearings in it. Now I need a new shift cable, R/F ball joint, some where around my gas tank theres a gas leak, and it needs a new full exhaust because its rusting out. I have not had this out in the woods or 4 wheeling. To my knowledge the exhaust is stainless steel and shouldn't rust out. The shop is telling me for a new exhaust its going to cost about $3000 because it has 3 cats on it 2 of which are on the Y pipe and 1 is on the straight part. My question to you all is ... is there any way 2 of the 3 cats can be bypassed like the 2 on the Y pipe and just have the 1 on the straight part ???
Ok never mind it runs like crap if you don't have all 3 cats on it ,
i did not know that they had a rust problem in new mexico
Didn't you have the vehicle inspected before purchase????
Sounds like a whole lot going on with your Monty, before you can even enjoy a good stretch. I'm not sure but if emission isn't a restriction where you are, maybe you can replace the first two with straight pipe. My two cents |
Originally Posted by mxmikie
(Post 290330)
Originally Posted by new_kid
(Post 290340)
Originally Posted by snides25
(Post 290417)
hey new kid I had it checked out buy a friend of mine which owns a garage told me that I have to have all 3 cats on it or it's going to overpower the o2 sensor and run like garbage so he's going to be doing the work to it on Monday and he also said that being that I took it to a dealership to be looked at but its is probably going to need is a patch job on a piece of pipe rather than a whole new exhaust
I was just making suggestions for you to get by, (if budget restricted) until further down the road. I do recall that the front; left and right converters are waaay expensive. The rear is not so bad though. Good luck. |
