02 Montero XLS Heat Issue Making Techs Scratch Their Heads
Old 10-28-2010 | 03:01 PM
john196899's Avatar
Default 02 Montero XLS Heat Issue Making Techs Scratch Their Heads
As the title indicates I have been unable to get any consistant information in regards a diagnosis. My 02 Montero XLS, with 145K miles has heat blowing from the driver's left side dash vent, and as you move closer to the passenger side, the heat is cooler and completely cold on the passenger right side dash vent. The same applies for the floor heat. I have gotten everything from a door might be open, to heater core. Has anyone out there experienced anything like this, and what was the remedy???? I don't want to get roped into replacing something I don't need to
Old 10-28-2010 | 06:52 PM
redturboeclipse's Avatar
which techs? mitsubishi dealer?
Old 10-29-2010 | 12:48 PM
john196899's Avatar
Dealer says it might be a heater core, and two other mechanics I have taken it to say it's not the core, it is something else. Their reasoning is that if the core was bad there would be no heat at all.
Old 10-30-2010 | 10:15 PM
mxmikie's Avatar
its the blend motor very comon
Old 11-08-2010 | 03:15 PM
john196899's Avatar
Default Thanks
Thanks for the info Mike, I really appreciate the assistance.
Old 02-18-2014 | 10:29 PM
kimzz69's Avatar
Default did it work John 196899
was it the blend door? im having the same issue.
Old 02-18-2014 | 10:31 PM
kimzz69's Avatar
or blend motor?
Old 08-30-2015 | 04:08 PM
elixirbooks's Avatar
Default Heater Remedy !
Same problem in 2001 Montero Limited. Little heat from driver vent but none on passenger. Turn on fan to max
Old 08-30-2015 | 04:12 PM
Turn on fan to the max. I used meat thermometer inserted in vent. Cycle between AC and heat 115xs and voila, heat started coming out of passenger side. Blend door had gotten stuck. 100° now. Best wishes.
Old 11-29-2017 | 11:39 PM
matt1992's Avatar
Was the blend door the confirmed fix? Did you have to replace the entire heater box or was the door replacable? Finding a good in depth parts diagram for this thing is next to impossible. My Montero should be similar, its a 2006 limited. Driver side swtiches from hot to cold and passenger side stays cold. Im pretty sure I seen the blend air door actuator move so I suspect a broken door in the air box.
Quick Reply: 02 Montero XLS Heat Issue Making Techs Scratch Their Heads
