02 Montero XLS Heat Issue Making Techs Scratch Their Heads
As the title indicates I have been unable to get any consistant information in regards a diagnosis. My 02 Montero XLS, with 145K miles has heat blowing from the driver's left side dash vent, and as you move closer to the passenger side, the heat is cooler and completely cold on the passenger right side dash vent. The same applies for the floor heat. I have gotten everything from a door might be open, to heater core. Has anyone out there experienced anything like this, and what was the remedy???? I don't want to get roped into replacing something I don't need to
Was the blend door the confirmed fix? Did you have to replace the entire heater box or was the door replacable? Finding a good in depth parts diagram for this thing is next to impossible. My Montero should be similar, its a 2006 limited. Driver side swtiches from hot to cold and passenger side stays cold. Im pretty sure I seen the blend air door actuator move so I suspect a broken door in the air box.
