02 Montero XLS Heat Issue Making Techs Scratch Their Heads
#21
I have to say - I never in my life had an issue with bleeding air form my Montero cooling system. Not when replacing fluid, not when I replaced various hoses (including hoses to the cabin heater core), not even when I pulled and rebuild the engine. Not once in all these times did I have an issue with bleeding air out of the system.
#23
Edit:
I'm actually in the process of picking up supplies to make my own heater valve system. Using an old EGR control solenoid from another monty and a vacuum controlled heater core valve from Oreilly's. I'm awaiting my relays and electrical supplies from amazon and some free time to install it. I plan on making use of the unused vac port on the top right corner of the plenum to connect to the solenoid.
#24
Thank you for reminding that Sport is often an entirely different animal from full size Montero. Not all experience with one style translates directly to the other.
As far as making your own HVAC controller - have you considered using an electrically actuated ball valve? They make them in 12v version and I'd think it might be easier to control it with power supply than with vacuum. Just a thought.
#25
