02 Montero XLS Heat Issue Making Techs Scratch Their Heads
Old Feb 5, 2021 | 05:08 PM
  #21
Naeos_Valkarian's Avatar
Originally Posted by HunterD
I have to say - I never in my life had an issue with bleeding air form my Montero cooling system. Not when replacing fluid, not when I replaced various hoses (including hoses to the cabin heater core), not even when I pulled and rebuild the engine. Not once in all these times did I have an issue with bleeding air out of the system.
I will agree that 90% of the time I don't have issues either, only one time did I have to jack up the front end and do this and I burped my system for almost an hour before I saw that it was finally done.
Old Feb 5, 2021 | 06:47 PM
  #22
One thing that may help prevent air grtting trapped in heater core, is to make sure your temperature control is set all the way on HOT before you do anything.
Old Feb 5, 2021 | 06:59 PM
  #23
Unfortunately this does nothing to help on Montero Sports due to the neglect of the engineers in charge of designing the HVAC system. There is no heater core valve to control the flow of coolant to/from the core, the flow is constant. This actually plays a role into why so many people complain about poor AC performance on these trucks. I noticed a huge increase in cooling performance when I bypassed my heater core when it blew. Now this isn't to say having it on full blast doesn't have any merit, it does help to monitor the performance of the heater as you burp the system.
Edit:
I'm actually in the process of picking up supplies to make my own heater valve system. Using an old EGR control solenoid from another monty and a vacuum controlled heater core valve from Oreilly's. I'm awaiting my relays and electrical supplies from amazon and some free time to install it. I plan on making use of the unused vac port on the top right corner of the plenum to connect to the solenoid.
Old Feb 5, 2021 | 08:39 PM
  #24
Thank you for reminding that Sport is often an entirely different animal from full size Montero. Not all experience with one style translates directly to the other.
As far as making your own HVAC controller - have you considered using an electrically actuated ball valve? They make them in 12v version and I'd think it might be easier to control it with power supply than with vacuum. Just a thought.
Old Feb 5, 2021 | 11:07 PM
  #25
When/If the solenoid fails I'll consider switching over to this, but unfortunately I already have purchased everything. I'll let y'all know how it turns out.
pharpe
Aug 27, 2013 06:43 PM
RCJr9186
Mar 19, 2008 12:30 PM
8000RPMS
Mar 7, 2007 04:02 PM
Eclipsor
Jun 20, 2006 03:14 PM
CalienteAutomotive
Dec 2, 2005 09:18 PM
