03 Montero - Can't get front rotors off
Old Aug 14, 2006 | 02:17 PM
jcasaccio's Avatar
Default 03 Montero - Can't get front rotors off
I was doing the front brakes yesterday and could not get the darn rotors off. I took off the caliper brackets and the rotors would not budge - even with a rubber mallet. What gives? I have done many brake jobs before and never had this happen.
Old Aug 14, 2006 | 08:22 PM
Manybrews's Avatar
Default RE: 03 Montero - Can't get front rotors off
a full size montero or a sport?
Old Aug 15, 2006 | 12:22 PM
jcasaccio's Avatar
Montero LTD - full size
Old Aug 16, 2006 | 12:09 AM
Manybrews's Avatar
there should be two screws retaining them.. have you removed the screws?
Old Mar 21, 2007 | 01:32 PM
jcasaccio's Avatar
I couldn't get those darn things off for a long time....
What the heck is the point of those screws anyway?[&o]
Old Mar 21, 2007 | 01:59 PM
tj90's Avatar
Try an impact screwdriver if you are having problems with the screws.
Old May 25, 2012 | 10:50 AM
BigBodyMonte95's Avatar
From: Anywhere... because I can live out of my Montero
You might not be able to get them off without totally disassembling the hub, thats how it is on older full sized Montero models (my 95 Montero you have to totally repack the bearings, and have a special lock ring tool). Be careful not to do anything too drastic without knowing exactly what you're doing, because repacking the bearings is a PAIN unless you're familiar with the procedure.
Old May 25, 2012 | 10:14 PM
Mr. Z.'s Avatar
So true, but at least you can repack your bearings, the Gen III bearings are non-serviceable.
mattyblast
Apr 12, 2018 02:55 PM
ultrarevvin1
Jan 14, 2014 10:38 AM
ultrarevvin1
Jan 11, 2014 07:13 PM
mikep1457
Sep 24, 2008 12:09 AM
PorscheNoSub
Jun 16, 2005 02:53 AM
