1989 Montero is overheating.
Old Jun 8, 2017 | 11:38 AM
bblauve's Avatar
Default 1989 Montero is overheating.
In the summer time only, and when thoroughly warmed up, the only way I can go after leaving a store is to prop the hood open. This is a pain, and I'm getting up in age so when I forget, I'm stuck waiting for an hour or more for the car to decide to let me go. Eventually the Montero decides to let me go on my way. Any ideas?
Bruce
Old Jun 8, 2017 | 02:49 PM
Based on the age, I'd say its possible that your radiator has reduced flow. If you have a shop in the area that specializes in radiators, you can take it off and have them clean/descale it. They will pressure test it to make sure there is no leaks and flow test to confirm that its good and meets specs.
Of course the other suspect can be a failing coolant pump. I'm pretty sure its one of those two.
Old Jun 8, 2017 | 03:54 PM
bblauve's Avatar
Thanks HunterD. I'll try that. I have a radiator shop here in Colorado Springs.
Old Jun 25, 2017 | 12:41 AM
mxmikie's Avatar
bad fan clutch
Old Jun 25, 2017 | 09:28 AM
bblauve's Avatar
Thanks mxmikie!
Bruce
socal1200r
13
Jul 28, 2013 07:55 PM
tdf
11
Oct 22, 2010 09:47 PM
cooljames
Jul 19, 2005 02:54 PM
1989Montero
Jul 8, 2004 08:21 PM
