1990 Montero/Rear brakes
Old Jun 6, 2007 | 09:55 AM
Pete D's Avatar
Default 1990 Montero/Rear brakes
I have a 1990 Montero, 2 door, V6, auto that I am setting up. Most of it's use will be on the street. I play a lot of sports and put approx 30K a year getting around todifferent events and do not want to put any more miles on the new cars so am building/refurbishing the Montero to carry that load.
My question is this. Can rear disc brakes be retro-fitted to this vehicle without replacing the rear differential? It's pretty much under braked with the rear drum configuration. Any feedbackre: going 4 wheel disc would be appreciated.
Old Jun 6, 2007 | 05:32 PM
off roader's Avatar
Default RE: 1990 Montero/Rear brakes
I'm sure it's possible to do w/out swapping the diff but it's easier to do if you swap the rear diff. Make sure if you get a new diff to purchase the entire assembly including trailing arms (bigger stronger in 2nd gen and bolts right up to 1st gen), and driveshaft (so you can swap p/o the u joints over) and also the brake cables IIRC.
That should be about it and it's supposed to bolt right up. If you want, send me a PM and I can put you in contact with someone who recently did this with their 89 2 door montero.
HTH.
monterojo
Apr 12, 2015 06:16 AM
msport_2_outlander
Jan 9, 2015 07:30 AM
cougar8000
Oct 12, 2005 12:34 PM
minhvo72
Jun 20, 2005 09:33 AM
theduke1959
Jan 16, 2005 11:41 AM
