90 montero rear brakes
Old Apr 10, 2015 | 08:44 PM
monterojo's Avatar
Question 90 montero rear brakes
Pulls right when braking, aligned, new brakes front, rear not bad. Adjusted correctly, BUT....with the rear wheels off ground, passenger side works as it should, but driver side wheel stops turning when brakes AREN"T applied.
Let brake pedal go, wheel stops turning.....as if you are braking
Old Apr 10, 2015 | 09:10 PM
Akzle's Avatar
binding caliper
Old Apr 11, 2015 | 04:51 AM
monterojo's Avatar
Default rear brakes
Drum brakes on rear, no caliper. driver's side has (2) brake lines to it, one from master, other looks like it comes out going to other wheel, no visible leaks.
Old Apr 11, 2015 | 09:13 AM
Akzle's Avatar
binding shoes
Old Apr 11, 2015 | 09:15 AM
Akzle's Avatar
you should have a proportioning valve under there too.
Leaks would cause lack of braking.
Old Apr 11, 2015 | 09:39 PM
monterojo's Avatar
Thanx, that is something that makes sense..checking next
Old Apr 12, 2015 | 06:16 AM
rupenzelleo's Avatar
hoh nice replies...
msport_2_outlander
Jan 9, 2015 07:30 AM
Pete D
Jun 6, 2007 05:32 PM
cougar8000
Oct 12, 2005 12:34 PM
minhvo72
Jun 20, 2005 09:33 AM
theduke1959
Jan 16, 2005 11:41 AM
