1994 3.5l Montero 2 row vs 3 row radiator
Hello everyone,
I need help on this issue. My 1994 3.5l Montero seems to overheat as it's driven in harsh environment with A/C on. What I found out what that V6 monteros all come with 2 row radiators. My questions is, what do you need to do to convert it to 3 row radiator? I would appreciate a detailed instructions, i.g. what parts need to be modified with what, etc?
Thank you,
MM
Thank you,
MM
What have you done to lead you to believe that you need a new radiator?
Have you tried pulling it and getting it rodded out?
If you do make sure you do a complete engine flush (not a drain and fill).
Both of these moves may save you the purchase.
(I'm not even sure the radiator you are speaking of will fit as a bolt on...)
Good Luck
Good Luck
montplusrs
Jan 31, 2014 05:05 PM
montplusrs
Jan 31, 2014 12:45 PM
guillermoblnc
Nov 6, 2010 05:15 AM
jodynkumo
Jul 22, 2010 06:28 AM
1994, 35, adding, core, forum, mitsubishi, montero, oil, overheating, performance, radiator, row, rows, sport, v6
