1995 montero SR - Which service manual has timing errors anyone know?
Old Oct 14, 2014 | 08:46 PM
shownuff80's Avatar
Default 1995 montero SR - Which service manual has timing errors anyone know?
Getting ready to do the timing belt(128K), water pump , valve seals(SMOKING ISSUES) and everything in between and have been researching online and I guess theres a manual with the wrong timing information in it but cant find out which one does anyone know? Any info would be helpful thanx.
Old Oct 15, 2014 | 03:30 AM
Akzle's Avatar
if you havent already started, and there really are no markings (highly unlikely) then make your own when you have #1 @tdc.
Old Oct 15, 2014 | 06:55 PM
shownuff80's Avatar
Thanx ax for the reply. After alil more research Ive figured out its the manual from www.mitsubishilinks.com regarding the 3.5 v6 engine timing procedure, from what ive read these steps will cause valve and piston interference so just to be safe im not going to use it. But im pulling the heads so as long as I have all my marks on point I should be ok in theory. Im not sure which cylinder is #1 since I havent bought a service manual yet. but as soon as I start Ill be posting pics of the surgery. And hopefully I dont break the crank pulley bolt opon removal.
Old Oct 16, 2014 | 01:05 AM
Akzle's Avatar
either front left or back right. depends whether the jappo foreman had sake for lunch before turning out the cranks...
Old Oct 23, 2014 | 12:43 AM
You've got a big job ahead of you. I believe Cylinder No. 1 is front passenger side.
Old Oct 23, 2014 | 04:23 PM
shownuff80's Avatar
Yes I do and not looking foward to it but at least once I get it done I'll know my engine alot more which is a good thing. Prob. be startn the procedure in a week or two once i get the timing belt and service manual.Im gonna try and take pics as I go so I can post.
Old Oct 31, 2015 | 01:23 AM
Oleg Kriger's Avatar
Justincredible90
Aug 15, 2024 02:39 PM
Teamtraction
Feb 25, 2013 01:50 PM
jnetter
Aug 10, 2008 12:48 PM
ictponder
Mar 21, 2006 10:03 AM
junque
Jun 27, 2005 12:04 AM
