1996 Mitsubishi Montero Check Engine light!!
Old May 28, 2013 | 07:08 PM
cdvyas20's Avatar
Unhappy 1996 Mitsubishi Montero Check Engine light!!
My Mits montero 3.0 has Check engine light on and when i put the diagnostic in, the problem is the P0161 O2 Sensor Heater Circuit Malfunction. The cars runs the same and the performance is not effected but i need to get the smog check done and i have to fix this problem before. Pls help ASAP!!
Thanks
Old May 29, 2013 | 05:31 PM
go-part's Avatar
Former Sponsor
OBD-II Trouble Code: P0161 Oxygen O2 Sensor Circuit Low Voltage (Bank2, Sensor2)
Check the wiring to your o2 sensors, if all looks fine then you may need to replace them.
Old May 29, 2013 | 09:44 PM
cdvyas20's Avatar
So can I just replace the o2 sensor to solve the problem instead of going too deep in it?
guyjg
Nov 13, 2021 03:27 PM
AGTrauger
Jul 20, 2013 11:48 AM
salsomano1a
Apr 1, 2012 11:41 AM
cjernigan
Apr 24, 2010 09:22 AM
pgb205
Jun 4, 2009 10:40 PM
