1996 Montero center console
Old Jan 22, 2011 | 02:44 PM
GilbertLarra's Avatar
Default 1996 Montero center console
Hi guys I'm trying to remove the center console of my monty to install a volt gauge. The only thing that wont let me is the 4x4 shifter (don't know how it is called). Any idea how to remove this?
Old Jan 23, 2011 | 01:43 PM
jrmdir's Avatar
Mine's a '99 but that **** simply unscrews as I recall. Don't see why yours should be different. If pure twisting force won't work there may be a jamb nut at the bottom that needs to be backed off. It's recessed up into the soft rubber lip at the bottom of the ****, See if you can force the proper size open end wrench up in there to back it off or at least hold it while you unscrew the ****. Hope this helps.
Old Jan 24, 2011 | 03:50 PM
Thanks a lot!!
skylerhall
Jul 15, 2010 10:01 AM
aejaypee
Feb 4, 2009 11:55 AM
gobbler33
Dec 18, 2006 08:47 AM
VENGE
Oct 9, 2005 05:02 AM
Flipz
Apr 29, 2005 03:37 PM
