1996 Montero - Need New Engine
Old May 27, 2008 | 02:33 PM
vytnom77's Avatar
Default 1996 Montero - Need New Engine
Ok my check engine light came on my car and I took it into the shop and they told me that my lifters are bad and that my engine is burning oil. They are suggesting that I can either fix the internals which they did not recommend because it would be too costly or to just get a new engine.
I've chosen just to get a new engine so I guess my questionis, since I'm doing the engine swap are there any upgrades to the standard engine that I can get that will be better? I think I was reading my options were a 6g72, 6g74and a 6g74 GDI, based on the wiki I found.
http://en.wikipedia.org/wiki/Mitsubishi_6G7x_engine
Any suggestions as to where to look and possible installers would be great also. Admins please move if I have posted this in the wrong section. I did not see a complete engine section under technical.
Monty
Corona, Southern California
Old May 30, 2008 | 10:54 PM
mxmikie's Avatar
Default RE: 1996 Montero - Need New Engine
sounds like the mitsubishi leaky valve stem leak and the famous ticking mitsubishi lifetrs
Old Jun 20, 2008 | 10:14 PM
lwolfnmonty's Avatar
mitsubishi told my parents that I needed a new engine about 8 years ago, and I am still driving it. you are good for while, it sound like it is the same scenario. I would get an engine out of a junkyard and rebuild it then drop it in. you can bore it out to get more power and add a cold air intake, but because the engine compartment is so small, your options are limited.
cdvyas20
May 29, 2013 09:44 PM
dave52355
Apr 28, 2012 10:47 PM
kwlandry
Mar 19, 2011 03:09 PM
Tennessee Eclipse
Aug 10, 2007 12:19 PM
rgwebster3
Aug 29, 2004 06:59 PM
