1999 Montero antenna replacement with fixed whip
Old Aug 4, 2011 | 10:18 PM
sandhuatmit's Avatar
Default 1999 Montero antenna replacement with fixed whip
My 99' Montero's power antenna is broken. It is fully extended, but won't retract and I can hear the motor run on/off as the stereo is turned on/off. Is it easier to replace the antenna with a simple fixed whip? If yes, how?
Thanks!
Old Aug 4, 2011 | 11:23 PM
mxmikie's Avatar
just change the mast
Old Aug 5, 2011 | 08:15 AM
Haynes1701's Avatar
X2
Since you can hear the motor running, then the motor's probably OK. Just buy a new power antenna mast. I recently did this in my '01. The antenna would retract to about a foot and stop. Replaced the mast with a new one which took about 2 minutes. Cost about $60. Can't remember the name of the store I bought it from (online). Do a Google search for Montero Power Antenna Mast and you'll find it.
bgreen1922
Apr 10, 2010 12:28 AM
tidus10
Nov 24, 2009 12:56 AM
tidus10
Mar 12, 2008 01:16 PM
superinflamo
Dec 22, 2006 09:00 AM
willdue
Jun 16, 2006 03:58 PM
