-   Mitsubishi Montero & Montero Sport (https://mitsubishiforum.com/forum/mitsubishi-montero-montero-sport-14/)
-   -   1999 Montero Ignition Control Module or Capacitor? (https://mitsubishiforum.com/forum/mitsubishi-montero-montero-sport-14/1999-montero-ignition-control-module-capacitor-57367/)
1960StudebakerHawk Jun 8, 2024 04:40 PM
I was helping a friend on his 1999 Montero with the 3.5 Single Overhead Cam V6. He made an attempt at replacing the valve seals (with engine installed), and dealing with those darn "keepers" which hold the valve springs in place is a royal pain. Maybe I should do a separate thread on that ordeal.
After getting the engine all back together, he has the "Crank-No Spark-No Start" issue. It ran fine before working on the engine. There is no spark coming out of the three coil paks, and a bizarre voltage of only about 6 volts going to the coil paks.
We finally noticed that the "flux capacitor", with a real name of "Ignition Capacitor" had worn wires coming out of it which had finally broken away. Here is a picture:
The wires had broken away, and we believe this is why the coil paks are not producing spark.
https://cimg2.ibsrv.net/gimg/mitsubi...c53ae8a7a2.jpg
https://cimg1.ibsrv.net/gimg/mitsubi...83a681a0f9.jpg
The strange thing is that we cannot find this part number (250/0.47 N78C L) anywhere. Also, the parts suppliers do not show anything like this. Anyone know if this part is supposed to be used with this engine? The original owner could have substituted this wrong part year ago.
My 1994 Monteros have an Ignition Control Module and does not have this little capicitor. Is it possible that this 99 Montero is also supposed to have the Ignition Control Module that looks like this?: (This is the part that comes up at Rock Auto and other parts stores):
If someone has a 99 Montero, let me know what you find under your hood.
https://cimg4.ibsrv.net/gimg/mitsubi...6ec48617e5.jpg
1960StudebakerHawk Jun 13, 2024 04:06 PM
UPDATE: Actually, the 99 Montero does have the Ignition Control Module, identical to the one on my 94 Montero. However, I found out that my 94 has the wierd "Ignition Capicitior or Ignition Transistor" right at the end of a plug that plugs into the Ignition Control Module. For some reason, Mitsubishi changed it for 99 and made it totally seperate from the ICM. After many hours researching for this little part, he finally found a Mitsu. dealer who blew off the dust on some old books, inserted a floppy drive disc, and went back to the Fortran punch cards to find that the part did exist, and there were only 5 left in the country. So, grab them while you can if you have a 99 Montero.
HunterD Jun 14, 2024 11:45 PM
Great job figuring out the answer to the mystery. The original part in your photo looks like it has wires all melted. Did it short out somewhere?
1960StudebakerHawk Jun 15, 2024 06:27 AM
I guess the Prior Owner had it parked beside that old DeLorean outside the church bell tower when the bolt of lightning struck.......good for the flux capacitor in the DeLorean and the mad scientist, but bad for the Ignition capacitor/transistor in the Monty.
It looks like someone had put some type of black glue/compound all over the wires.....and it lasted a long time like that, but it finally "gave up tha ghost".
Andrew Moore May 16, 2025 05:31 PM
Ignition control module thingy.
I know this is a long shot, but the exact same thing just broke on my 2000. Does anyone remember a part number for this capacitor/module? Thanks.
1960StudebakerHawk May 16, 2025 05:43 PM
Well, what part number is stamped on your defective part? Is it the same 250/0.47 number?
Andrew Moore May 16, 2025 06:51 PM
Sorry. Yes it is the same. But I can't find anything online used or new. Would Mitsubishi have a different part number? Like a MR something. Not skilled in finding things like this.
1960StudebakerHawk May 16, 2025 07:25 PM
Andrew......I will do some checking and get back to you. I guess that I should have been more effecient in the prior posts and given the name of the supplier.
Andrew Moore May 17, 2025 08:34 AM
Thank you. Any help is greatly appreciated.
HunterD May 17, 2025 08:59 PM
Good detective work. I wonder if it is possible to McGiver some sort of harness modification to make the newer ignition control module work in place of this very rare part? Does anyone have schematic that show what is I side of it and how it relates to the newer part?
