2 problems. Any ideas what it could be? 02 limited
Old Mar 27, 2006 | 02:12 PM
TRUOMEGA's Avatar
Default 2 problems. Any ideas what it could be? 02 limited
Hey all... I have 2002 montero limited automatic. Car has 23000 miles on it. Problem is that it makes a chattering sound wher the car is at idle. The sound/problem doesnt seem to affect the cars performance but its real loud when warming up and still noticably loud when warmed up. Sound is comming from underneath engine. Cant pinpoint exactly but sounds more like the front bottom area. Not to sure and hard to tell.
Also i have a problem with the digital climate control. For whatever reason, when the car first starts up int he morning its set to 75 degrees but as the car is driven, the temp coming out the vents is like maximum heat and no matter what setting i put it on with the exception of the lowest setting (65 degrees) it will continue to push out maximum heat temps. If i shut the car off and then turn it back on 5 min later then it will work properly where it would be consistant witht he temp setting.
Any response given to either problem will be greatfull. Thanx in advance.
Old Aug 10, 2006 | 12:52 AM
atasic's Avatar
Default RE: 2 problems. Any ideas what it could be? 02 limited
You have probably solved your problems by now, but anyway on the first I had the same type chatter and it turned out to be alternator belt tensioner roller. That got replaced and noice gone.
Old Aug 10, 2006 | 07:21 PM
Manybrews's Avatar
probably the hydaulic timing belt tensioner. get it looked at quickly.
Old Nov 20, 2006 | 06:35 PM
TRUOMEGA's Avatar
Actually i havent had the problem solved. Guys at the dealership told me that its normal and that all them make that sound so i opted to wait till whatever the noise was (now i know) breaks down in order to resolve the issue. Thanx in advance for the solution as people on forums are much more competent and knowledgeable than the dealerships.
Old Nov 27, 2006 | 11:36 AM
ken lally's Avatar
r u new to this car?- sounds like the same question I asked when i first bought the car... "what is this chattering I asked".... was told that it's the hydrolic lifters, I just was not used to that. Mine is a '01, same car though as the '02...
tidus10
Jun 24, 2009 02:20 AM
iwantmooreshawn
Oct 25, 2006 02:59 PM
mitsuazhelp
Oct 8, 2006 08:41 PM
5Tizzle
Oct 5, 2006 02:16 PM
xXEcLipse GTXx
Feb 24, 2004 01:31 AM
