2000 Montero Sport Electical Issues
Old Jan 23, 2009 | 07:27 AM
titoslack's Avatar
Default 2000 Montero Sport Electical Issues
I am looking to see if anyone can offer any guidance what so ever. My wifes Montero has been having issues. As of late when driving the radio will cut out. It doesn't happen al of the time. Ususally when it has sat over night. I have noticed that it happens primarily when you hit the breaks. When you hit the breaks when you are idling the lights will dim. When you are driving at slower speeds the lights will dim and the radio will periodically cut out/lose power. When you are on the highway the lights will dim, the radio will cut out/lose power and the Temperature gague in the rear view mirror will lose power and reset. The thing that throws me off is that it doesn't happen all of the time.
Please let me know what you guys think/how this can be fixed. Also, if you need any more information please let me know.
Old Jan 23, 2009 | 08:54 AM
nativa's Avatar
Default RE: 2000 Montero Sport Electical Issues
BAD Battery. get it tested. turn your key to the on position(dont start it) then put on the radio and your lights while looking at the battery gauge. if it moves below 12 then replace it.
A bad alternator if all else fails.
Old Jan 23, 2009 | 09:11 AM
titoslack's Avatar
Does that explain that it cuts in and out when the brakes are hit? I am confused by that.
Old Jan 23, 2009 | 02:03 PM
nativa's Avatar
The brake lights draw power to light. plusABS etc. get the battery and alternator tested if they are good then its fuse searching for u.
Once had a bad brake bulb cause some issues on a cherokee in d past. check the based of the bulbs for black burn marks as well
MoralDK
Jun 18, 2015 04:37 PM
wbauer
Sep 1, 2014 01:51 PM
JFENDERSON91
Oct 10, 2012 11:24 AM
ssuleski30
Jan 24, 2011 04:09 PM
the7spades
Mar 18, 2007 07:27 PM
