2001 Montero limited P0400 & P0431
Old Nov 23, 2018 | 08:04 PM
Tony Petro's Avatar
Default 2001 Montero limited P0400 & P0431
My inlaws have a 2001 Montero limited, which when given some gas I can hear a massive exhaust leak, in addition the check engine light is on. Upon a quick inspection I could see that the Catalytic converter is literally cracked in half. I ran diagnostic check and pulled the codes P0400 and P0431. I know the Cat needs to be replaced and maybe the egr sensor. I plan on digging into it this week to try and repair it myself.
Just wanted to see if anyone had any other suggestions/recommendations to check while I'm at it. Additional note, the engine was replaced around 40k miles ago and runs strong.
Old Nov 24, 2018 | 04:00 PM
For EGR code (P0400) check to make sure the ERG valve operates properly AND that there is no debris clogging the pipe or valve ports. If those components work as intended, you may need new ERG solenoid. If you do, make sure to get MITSUBISHI solenoid. The aftermarket ones do not work too well. Before you replace any ERG related parts, check all vacuum lines and their routing. A cracked or incorrectly routed vacuum line will cause a malfunction.
Caliedua
Apr 16, 2018 03:41 PM
wilde
May 31, 2016 01:11 AM
sharpjs1
Sep 16, 2015 09:20 PM
5280montero
Aug 15, 2011 05:44 PM
sierrenity
Apr 29, 2009 10:09 AM
