2001 Montero Sport XLS 4X2 Locker options
Old Mar 23, 2015 | 12:02 PM
Nice job.
You should check to see if you can pull the front axle and transfer case from the same donor and turn your Montero into a 4x4.
Old Mar 23, 2015 | 02:25 PM
usandthem's Avatar
Originally Posted by HunterD
Nice job.
Do you know if the front axle parts from the SR will fit under the MS? To be honest I haven't ever looked into it. I just assumed a 4x4 conversion would need front axle components from a 4x4 MS.
Old Mar 24, 2015 | 10:45 AM
No clue. I just thought that if the back end bolted right on, there might be a good chance that the front end will work too. Worth checking out.
Old Mar 24, 2015 | 11:59 AM
usandthem's Avatar
Just to clarify, in case someone reads this later, the back end of the SR did not bolt right into the MS. The spring mounts are not in the same location on the vehicles. All I was saying is that I purchased the whole SR rear axle assembly, removed the components I needed and installed them into the MS axle housing.
Edgar Roberts
May 24, 2014 03:15 PM
kvnhrkns
Feb 26, 2010 02:52 PM
cashcase
Feb 14, 2009 05:06 PM
Montero
Oct 15, 2004 10:35 PM
