3Questions on an 89'Montero's 4x4, HeadlightWasher, and BackDoor Locker. Can any1 suggest? thx
Old Oct 15, 2004 | 10:35 PM
Montero's Avatar
Default 3Questions on an 89'Montero's 4x4, HeadlightWasher, and BackDoor Locker. Can any1 suggest? thx
I have a 89 montero. Its working perfectly except for the 4x4, and back door. When I press the unlock or lock button for the back door, it doesn't do anything. After I press it about 45 times, it works, but only once. Then you have to keep pressing it again for it to work? What could be wrong?
On the 4x4 issue, a mechanic said something about a pin being missing. When I put it in 4x4, it makes weird sounds and shakes a little. Im too scared to test it. He said something was wrong.
And on the headlight washer, my car never came with it. The blinker sometimes didn't blink and I got a new switch for it. The new one came with a headlight washer switch? CAN I USE THE WASHER NOW? Or do I have to buy something else? Thanks. Please respond.
Old Oct 16, 2004 | 07:49 PM
1398spdr's Avatar
Default RE: 3Questions on an 89'Montero's 4x4, HeadlightWasher, and BackDoor Locker. Can any1 suggest? thx
rear hatch is probly a faulty relay or the wiring.............
Old Jan 28, 2006 | 11:39 AM
Akmikek's Avatar
I have had problems with the rear latch and it turned out to be a plastic barrier they placed under the back trim.Remove it from around the inside latch and handle mechanism and oil your latch and it should work fine.
Old Jan 20, 2022 | 10:31 AM
JBKeet's Avatar
bump on this super old thread - my back door won't lock. When I hit the switch up front, I hear the mechanism click in the back, but the door isn't actually locked. The handle to open the door works fine from the inside and outside - the key will turn both left and right, but can't figure out how to get the lock to actually engage.
Also - I've got the problem with the automatic locks - what configuration will keep them from continuously locking themselves when I try to unlock it with the key from the outside (i don't have keyless). When I have the doors locked and try to unlock with the key, the lock will pop up when I turn the key but then automatically just go right back down.
Deck Wood
Nov 5, 2024 01:29 AM
RoGuE_StreaK
Jun 6, 2016 11:12 PM
icu222much
Nov 2, 2014 09:57 AM
Naiok
Sep 17, 2010 11:28 PM
hsvgalant
Aug 8, 2009 07:41 AM
