97 300gt Door lock issue
Old Sep 16, 2010 | 10:57 PM
Naiok's Avatar
Default 97 3000gt Door lock issue
I just recently bought a 97 3000gt. My first mitsubishi.
I purchased from a private seller and did not check the door locks like a dummy.
So, this is my situation. Neither doors will unlock with the key. The Key does unlock the trunk and of course starts the engine just fine.
What would cause this? The locks 'seem' like they may be electric base so the first thing I checked were all of the fuses, which i didn't find any issue.
Anything else I should check?
Old Sep 17, 2010 | 04:41 PM
MitsMaster's Avatar
If the key turns in the door lock cylinder, the linkage rods been knocked off, probably by someone trying to unlock the door with a slim-jim. You need to pull the door panels and check it out.
Old Sep 17, 2010 | 10:34 PM
Naiok's Avatar
The key does NOT turn. The electric locks on the inside will lock the door and will manually lock from the inside, but the key will not turn the locks from the outside.
Old Sep 17, 2010 | 11:28 PM
MitsMaster's Avatar
take the door panel off, remove the linkage rod from the door lock cylinder. If the key turns then, you need a latch. If it doesnt turn you need new lock cyls.
crazycar2000
Oct 17, 2010 04:56 AM
n5926g
Sep 28, 2007 05:19 AM
99Eclipse_RS
Apr 18, 2005 02:55 PM
metamaster
Oct 21, 2004 02:28 PM
91eclipse
Mar 18, 2004 04:54 PM
