2002 Montero Limited Rear Wiper Fluid Dispenser
Old Apr 14, 2015 | 10:38 AM
AfroGeek's Avatar
Default 2002 Montero Limited Rear Wiper Fluid Dispenser
So, while checking the fluids, the rear windshield fluid dispenser somehow leaks INSIDE the rear window. I just did a quick look and didn't see an obvious dispenser anywhere. Is it on the wiper mechanism itself? If this is a common problem, is it easy to get to it?
Old Apr 14, 2015 | 05:01 PM
The spray nozzle should be above the window on the metal part of the door (black plastic about 1x1x1 cm). It is possible that the hose came off inside. If that is the case, you can remove the internal plastic door parts to get to it.
newoutlanderfan
Mar 3, 2015 07:44 AM
Harv
Feb 24, 2013 08:36 AM
ace of spades
Apr 5, 2009 03:35 PM
jcasaccio
Jun 6, 2006 06:14 PM
firerice
Dec 1, 2005 07:13 PM
