2002 Montero Limited tune-up and valve cover change
Hello, I have a 2002 Montero Limited. I am going to change the spark plugs, plug seals, upper and lower intake manifold gaskets, and valve cover gaskets, and rear cam plug seals. My question is does anyone know what the torque settings are for the manifold and valve cover gasket seals? I've looked everywhere from forums to youtube and knowone gets into the specific torque settings. Can anyone help me out? Thanks, just trying to save a buck from going to the dealer.
Here is a link to a FSM.
The torque specs are all on the last couple of pages. Hope it helps. http://www.pajero4x4.ru/piii/GR00003800-11B.pdf |
Thanks man! That helped a bunch! Much appreciated!!
Have you already gotten the valve covers off? Mine were tough, had to use a hammer+wood block and bang on them from the side to break the seal. Also, the previous gasket material didn't pull out, had to dig it all out with an awl. It's a pain, but doable.
Haven't started yet. Wanted to make sure I had all the specs before I open all that up. I plan I starting the operation this Saturday. I've only done jobs like this a couple of times before on other cars but never a Montero. We'll see how it goes this weekend and I'll post a thread if I survive..lol Thanks.
Originally Posted by mvious
(Post 281688)
Hi, No, I have not cleared the deck. Currently removing bolts from intake manifold. I was told that the gasket was a bear, and that scrap with an awl or screwdriver might be necessary. I tried hitting it with a rubber mallet, next I will try to pry the valve cover off. |
valve cover
Originally Posted by monteromorgan
(Post 287849)
I was told that the gasket was a bear, and that scrap with an awl or screwdriver might be necessary. I tried hitting it with a rubber mallet, next I will try to pry the valve cover off. Good Luck |
Spark Plugs
Originally Posted by ntpatel62
(Post 281627)
Do you know of a video or Diagrams that explains how to change the Spark Plugs on a Montero ? |
Originally Posted by ozziedesigns
(Post 289945)
Hi I am new here but in the process of changing the valve cover gaskets, plug wires, Plenum gasket and eventually the timing belt. I have a 2001 Montero Sport XS 3.5
Do the timing belt covers have to come off in order to remove the valve covers? It almost looks like the valve covers have a lip on the front and go under the timing belt covers? I'd appreciate any help. This project is getting to me. I should probably start a new thread but I am not sure how yet. Newby Thanks |
