2002 Montero Repair Manual
Old Mar 10, 2011 | 04:52 AM
dannman711's Avatar
Default 2002 Montero Repair Manual
Hey does anyone have the repair manual via PDF for the 2001-2002 Montero I was able to find the maual for 2003 and although they are very similar they have the 3.8L i believe as to the 3.5L on the 01-02 models thanks
Old Mar 10, 2011 | 05:02 AM
Have you tried google?
Most Autozones should carry that.
Old Mar 11, 2011 | 02:47 PM
2k1monterosport's Avatar
Is there a certain part You are looking for. I have the 01-06 manual on PDF
Old Mar 11, 2011 | 09:17 PM
Perfect! Why not host the file on an online server, then post the download link?
Old Mar 12, 2011 | 12:36 PM
dannman711's Avatar
Hey 2k1 If you dont mind could you please maybe email it to me if you dont feel comfortable posting it unless you are ok with it could you post the download link. Thanks as for the other comment believe it or not Ive checked with Autozone and O'riellys and they cant get the repair manuals because Chilton or the other company doesnt make it.
Old Mar 19, 2011 | 08:14 PM
marcusv22's Avatar
hello, is there anyway u can send me the pdf file? i am rebuilding the engine in my 2002 and i need the torque specs and the timing. it would be great to have the full file so i can trouble shoot it also.
thanks
Old May 2, 2011 | 10:03 PM
azsungal77's Avatar
Default did anyone get any help with an 02 montero manual?
I saw that someone had a pdf. Did anyone receive it? I have hunted online and off and so far can't locate one. My baby is down til I find one. And can someone tell me what is on the end of sparkplug wire number 3? whatever it is looks like a tube and the rubber grommet has blown out. It is under the throttle body? and I haven't seen anything like it, thus the need for a manual.
Old May 3, 2011 | 01:14 PM
mothman52's Avatar
Second one down on the page. Haynes. 97 ~ 05 Montero. $39.95.
http://www.books4cars.com/listings.p...ar=2002&type=%
azsungal77, check your PM.
Old May 3, 2011 | 02:16 PM
mvious's Avatar
Try http://www.pajero4x4.ru/piii/, you can download the PDFs here
Old May 3, 2011 | 08:47 PM
azsungal77's Avatar
Default Found download for Montero 2001-2006
http://www.tradebit.com/filedetail.p...nual-2001-2006
Only $10.99 The guy says it contains my motor, the 3.5L, whereas the others I downloaded though said they were 2002 turned out to be 2000 and 2003.
And thank you for the Haynes!
Between them I should figure it out. It turns out that, my guess is, when the plugs were changed number 3 was not tightened down. It popped right out off the whole wedging it under plenum. I got it out and plug is fine, threads are fine. Maybe over time vibration? Would this occur if my son put too much oil in? He says no as tube separates plugs from valves.
Anyway if you have an idea what caused it I would like to know. I can't see any other damage. But should I keep looking?
