2002 Montero Sport 4x4, oil pan gasket replace?
Hi:
I'm new on the forum, I have a 2002 Montero Sport 4x4, is leaking oil from the gasket of the motor oil pan. My question is; to replace this gasket I have to or may I have to:
A) lift the motor and transmission together, loosing the motor mounts ?
B) Take the motor out?
C) Or is easier to take the whole front suspension out low the front differential to have access to the oil pan?
In other words which is the easier way to replace that gasket?
Thanks in advance for all the comments and advices
Victor
Victor
The motor is a 3.5l, and yes if I lift the motor
I will have to loose a lot of things!!!
montey cosmopolitan
May 3, 2015 08:46 PM
ShingenTokugawa
Apr 5, 2009 08:19 AM
2002, 4x4, change, front, gasket, leaking, mitsubishi, montero, oil, pan, replace, replacement, seal, sport, transmission
