2002 Montero Timing Belt
Old Nov 15, 2011 | 12:33 AM
  #31
cpredone's Avatar
Default would appreciate the pdf file also in dire straits thanks cpreddragon@gmail.com
Originally Posted by marcusv22
Can you please send me the pdf file to marcusv22@yahoo.com ?
Thanks
Old Dec 28, 2011 | 12:02 PM
  #32
redraif's Avatar
If anyone has the pdf... my daughter just got a 2001 montero sport xls. It was badly neglected by a previous owner, so I know I will be working on soon!
Thank you!
redraif@yahoo.com
Old Jan 1, 2012 | 12:07 AM
  #33
jp2000's Avatar
Hi. Having some problems out of my 2000 montero sport. Had the timing belt replaced and also all other belts but now I've got a bad rattle somewhere in the motor when I start the motor. Belts loose? I've also heard that it may be the front pump on transmission? Any ideas?
Old Jan 21, 2012 | 12:35 PM
  #34
Smurray's Avatar
Default 2000 Sport, 3000 24v
Pfd. On timing belt replacement? Oil leak shorting alternator, where is the leak and quick fix? THANKS
Old Jan 21, 2012 | 12:36 PM
  #35
Smurray's Avatar
me too.... Any answers?
Old Feb 1, 2012 | 08:42 PM
  #36
redraif's Avatar
Yipes... no pdf? any other sources?
Old Feb 16, 2012 | 03:39 PM
  #37
Volvophile's Avatar
Would you mind sharing that pdf with me as well?
kaboby22@gmail.com
Thank You.
Old Apr 20, 2012 | 09:44 PM
  #38
mitsufamily's Avatar
If you may be so kind. Thank you. familia1@optonline.net
Old May 3, 2012 | 12:39 AM
  #39
Evan Yoder's Avatar
ok this has nothing to do with this, but I'm new here and I don't know how to start my own question. Anyways, I just bought an 02 Montero Sport XLS with 86k miles on it from the original owner who had it dealer maintained. But my engine started tapping/ticking and I'm assuming its the lifters. It doesn't go away. I've already tried the whole revving the engine to 3rpms to clear out the lifters and that didn't help. I've done it several times. I'm using Valvoline Maxlife 10w30 with a wix oil filter. I did have to replace the valve cover gasket when I bought it, they were leaking a bit. I'm assuming maybe the lifters were deprived of oil from the gaskets leaking. But I was told the ticking was normal and not to worry about. But this doesn't seem normal with only 86k miles. Any advice would help. I was quoted $975 to replace all my lifters.
Old Aug 10, 2012 | 02:10 PM
  #40
MBellar's Avatar
Can you send me the PDF also.
monte.bellar@c-a-m.com
Thanks
