2003 Montero Limited Yellow Light
Old May 2, 2012 | 05:23 PM
  #21
JoseM's Avatar
Originally Posted by JoseM
Reviving an old thread...
Got a 2003 Montero Limited with the same yellow blinking light problem, will try cleanning out the switches first.
I've been trying to find them on different Mit (online) autopart stores, but no luck. Any advice?
Well, problem solved -- for now ... One of the solenoids was not working propperly. Let see how it all goes from now...
Old May 4, 2012 | 11:46 AM
  #22
tzentgraf's Avatar
captain chuck have you replaced the sensor located on the passenger side fender under the hood it has vacuum lines and wires attached it runs around $111.00 according to the dealer if you can find one at the junk yard you might get luckey one of the sensors has a blue dot the other one has a yellow dot on it and they both set side by side
Old May 4, 2012 | 05:12 PM
  #23
JoseM's Avatar
This one?
I changed this one and problem solved
Old Jun 8, 2012 | 01:32 AM
  #24
shawnrex's Avatar
I have a 03 montero limited (Flashing yellow light Center diff) I did replaced the frontwheel engagement solenoid (that control the freewheel clutch assembly), this is the first thing I would check before you guys attempt to touch any other sensors by the transfer case. part # MR430381 dealers from southern california prices range $135-$145. . after I change this solenoid, the freewheel clutch assembly error symptom never came back. Im not a mechanic but did bought the 2003-2006 repair manual on disc found in ebay $17. good source of reference.
Old Jul 29, 2013 | 04:05 PM
  #25
maykel's Avatar
Default Hello my friend I'm new to your amazing website
Hello my friend I'm new to your amazing website I'm from Israel and enthusiasts Mitsubishi significant שלום.
Monterorider
Sep 21, 2013 10:22 AM
nvpurk
Jan 19, 2007 08:30 PM
boltex55
Feb 14, 2006 03:43 PM
alero440
Oct 18, 2005 05:14 PM
Delta Zulu
May 27, 2005 09:30 PM
