2003 Montero Sport Limited Question
Old Jan 18, 2007 | 03:01 AM
nvpurk's Avatar
Default 2003 Montero Sport Limited Question
Does anyone know if there's "extra" cooling on the transmission on the Limited model? I've read they're rated at towing a total of 5000 lbs. I'm looking at getting a small trailer to tow some things, and I don't want to over-do it.
Is the 3.5L engine an "Interference"-type engine?
Anyone know of a good, "small" shop to do the 60K service in the Reno, Nevada area?
That's probably enough questions for now :^) I've enjoyed lurking around...
Old Jan 18, 2007 | 08:07 PM
Manybrews's Avatar
Default RE: 2003 Montero Sport Limited Question
ORIGINAL: nvpurk
all the monteros and montero sports (in fact, almost all of mitsus trucks ever) have trans coolers, so you're fine. around 99 they increased the pan size and fluid capacity to help with things like towing, etc.
you shouldnt have a problem. I recommend keeping it out of overdrive if towing a very heavy load.
yes. all mitsu engines are.
aftermarket shops are usually run by complete meatheads. I recommend mitsu techs to work on mitsus.
also, although the timing belt is recommended at 60k (under severe conditions), its quite safe to the normal interval of 100k. Ive seen 190k on the original belt, but do NOT recommend that!
Old Jan 18, 2007 | 09:11 PM
off roader's Avatar
Actually the 3.0L SOHC engines are non-interference engines.
Old Jan 19, 2007 | 01:24 AM
nvpurk's Avatar
I appreciate your advice and information. Maybe I will consider the local dealer.... it makes sense to go to the ones who work on them for a living.
Thank you-
Old Jan 19, 2007 | 08:04 PM
Manybrews's Avatar
ORIGINAL: off roader
only the old 2 valvers in the monteros. they were interference in the diamantes. (im talking about pre 94-95).
and the new 4 valvers? DEFINATLY interference, regardless of the car/truck its in.
Old Jan 19, 2007 | 08:30 PM
off roader's Avatar
Yup. Just clarifying so if an 89-91 v6 montero owner reads it the won't think they're screwed because their timing belt broke.
Here's one I've never heard of until recently (probably pretty common though)...
My daily driver is a 95 Golf GL which is a non-interference engine under 25-35mph. Above that the valve movement is so much that it becomes an interference engine. Good thing I was making a turn on city streets when it's timing belt gave out.
Chuckles1956
Nov 25, 2017 05:53 PM
mitsfreak12
Apr 15, 2009 12:54 AM
johvig
15
Dec 9, 2007 12:15 AM
boltex55
Feb 14, 2006 03:43 PM
Delta Zulu
May 27, 2005 09:30 PM
