2003 Montero Sport 3.0 Can of worms and i dont want to open it.
Old Jul 21, 2019 | 07:28 PM
Bremboy71's Avatar
Default 2003 Montero Sport 3.0 Can of worms and i dont want to open it.
Hello fine people,
Well my issue persists. I have changed everything possible on this car and i truly need a hug from a Mitsubishi Technician that can assure me that this is how the car is.I have never had a a automatic so i will try to explain this issue.
If i am driving it up hill and it is in 3rd gear it will shift to 4th even if im still in need of a higher rpm!!! WTF!!!! If it is on a regular surface normal street and you are in 4th gear and need to accelerate unless you floor it, it will shift to 3rd. if you just step for a normal acceleration it will lower the rpm almost seems that your flooding it before it kicks and moves. The messed up part is that im not getting and codes on my scanner.
Items changed..
Fuel Pump
O2 Sensors
Transmission fluid doe not smell burnt and is at its normal values of height and color
Someone give me some ideas what the hell is going on with this truck.
Old Jul 22, 2019 | 11:54 AM
It sounds like an issue with the transmission controller. But to rule out other things... by any chance, do you have access to live data on your OBD2? Would be nice to see what is there when you are driving normally and when it does not down shift going up hill.
Old Sep 12, 2019 | 08:45 AM
Chuck U Farlie's Avatar
Fuel pump...
midnighteclipse97
Dec 10, 2017 09:43 PM
writersmark
Mar 2, 2014 09:29 AM
v1nce
Nov 30, 2010 10:36 PM
surfcandy
Jul 31, 2010 10:11 AM
Ralliart3000
Apr 22, 2008 12:06 AM
