Originally Posted by Fekey123
(Post 332114)
thanks...i understand that but after driving and in the operating temp of atf, the level is way below cold level almost no fluid...really puzzling to me.
Drive again. Re-check level. If you get it up to proper level, leave it there. In the next few drives check to see if you're loosing (leaking) fluid anywhere. I'd recommend that you top off transmisdion fluid ASAP. Having low levels is one of the primary causes for wrecking transmissions. |
thanks again.. will do just that
