2004 brakes
Old Dec 14, 2010 | 09:49 PM
PIRI PIRI's Avatar
Unhappy 2004 brakes
I was talking with a friend who works for my local dealership. He says that there has been a few Montero brakes going out. Is there a recall does anyone know? I checked and these parts are pricey.
Old Dec 14, 2010 | 11:40 PM
redturboeclipse's Avatar
2004 what? montero, or montero sport.
just 2004, or the entire 3rd gen USDM Montero (not sport) 01-06?
what part of the brake system?
Old Dec 15, 2010 | 10:28 PM
jgbrules's Avatar
been working for mitsubishi dealerships for 22 years, worked on hundreds of montero's. no common parts failure that i have seen. they did have a recall on the brake accumulator for 2001 models, but if that part did fail it would just make a squeaking noise when the brakes were applied. did not affect braking ability. most common thing i see is people wait untill the brakes start making a grinding noise, and it turns out the pad surface has completely worn off and the brakes are metal to metal. that can get expensive.
Old Jan 9, 2011 | 07:48 PM
PIRI PIRI's Avatar
I own a 2004 Montero, Its this gen. he said they replace the brake pump and accumulator.
Old Jan 16, 2011 | 07:26 PM
7-UP BILL's Avatar
I have an '02. I was sent a letter by Mitsu stating that there may have been a problem with said accumulator and that they were extending the warranty to 10 years for this part, if it went bad.
Old Jan 16, 2011 | 11:51 PM
can you scan the letter? what if you purchased the car used, thats why i asked, i would like a copy of the letter to show the dealerships
Old Jan 17, 2011 | 11:14 AM
FireDoc's Avatar
You don't need the letter. Mitsubishi will run your VIN to see if the part has been replaced. If it hasn't, they will arrange for the service. I bought my 02 Limited Montero second hand and had the accumulator replaced the same day it started making that chirping noise.
Old Jan 17, 2011 | 06:19 PM
PIRI PIRI's Avatar
Smile
Please this will be very use full for my truck in case?
msport_2_outlander
Jan 9, 2015 07:30 AM
froggiez
Sep 24, 2011 03:14 PM
trader eds
Jan 12, 2005 09:27 PM
ecotrans
Jan 12, 2004 09:21 PM
rollin_hard
Oct 29, 2003 03:52 PM
