3/6 coil not firing. Fixed
My 3/6 coil stopped firing last week on my 3.0 Sport. Swapped the coils around and discovered the coil was fine. After reading all pertinent posts and searching Google for solutions I found several ways to go: ignition control module, cam position sensor, crank position sensor, wiring, ECU, etc. Then I came across a post that stated "just change the ICM and be done with it" or words to that effect. So that's the way I went. 3 days later I had an ICM from Rock Auto, bolted it on, problem solved. Just thought I'd share.
So I replaced all plugs and wires cause it was all of a sudden running really rough and after replacing them still was missing so I unplugged coil one at a time got to coil 3/6 and nothing changed as far as idle I replaced coil still same thing I tried using one of the other coils I knew for sure was working and still same thing so then I went to a wrecking yard and pulled a ignition control module and installed and still nothing is it likely that that one I got would still make the same 3/6 coil not work or I just got a really bad luck of the draw not sure where to go from here or just buy a brand new one
