90 mighty max v6
Old Oct 15, 2013 | 06:42 PM
m80glostick's Avatar
Default 90 mighty max v6
hey i have a 90 mighty max v6 4w4.
same motor as the montero,
im getting no spark at all, started with getting spark most of the time.
now none of the time.
replaced distributor.
replaced ignition coil.
replaced icm.
have not replaced ecu or the little resistor thingy in line with the coil.
where should i check for what else could possibly be wrong with vehicle?
if i ground the solid white wire off the icm i get spark. which means im not getting a signal from something correct? if ther happens to be some magical relay or fuse i missed someone please tell me, would like to have truck for winter.
Old Oct 15, 2013 | 10:15 PM
mxmikie's Avatar
any burnt caps in the ecm ???
Old Oct 16, 2013 | 06:38 AM
Have not taken the Ecm of truck to look. Geussing something I should do
Old Oct 17, 2013 | 12:41 PM
Ok how do I post a pic of the ecu?
I believe it to be burnt out the chip in the center has black marks all around it.
Anybody have one? Or know where to get?
merlin
Jan 1, 2022 04:07 AM
spyderwoman59
Apr 17, 2020 01:11 AM
spiderrey
Mar 10, 2005 01:45 AM
