91 montero rs turn signals
Old Apr 26, 2006 | 06:16 AM
udg21's Avatar
Default 91 montero rs turn signals
i need help fixing my turn signals they dont work at all i checked the fuses and flashers even bought a new turn signal switch but wasnt the problem the emergency flashers do work. thanks
Old Apr 26, 2006 | 03:01 PM
off roader's Avatar
Default RE: 91 montero rs turn signals
It could be the turn signal switch or a electrical wiring issue... Do you have the schematics from the factory service manual? I know there's an 89 FSM available on a Russian Pajero site that's downloadable. The wiring should be the same for the lighting.
Old Apr 26, 2006 | 10:37 PM
udg21's Avatar
i tried the new switch and it didnt work either and i do need schematics
Old Apr 29, 2006 | 01:34 AM
01monteroltd's Avatar
i had same problem with my 01 ltd... it was the fuses .look in the engine compartment fuse box.. its the 15amp fuse that says brake and 10amp next to it .i only found it afte half dozen fuses tha t i pulled, i replaced ones thast were fried and everything camer back hope this helps
Old May 1, 2006 | 06:29 PM
udg21's Avatar
i have fixed it . the hazzard switch was bad
Old May 2, 2006 | 04:58 PM
off roader's Avatar
Glad you found the cause of your problems!
pinecone1000
Oct 9, 2009 11:48 AM
Mac_attack769
Sep 23, 2006 07:52 PM
fred
Oct 16, 2005 05:17 PM
Britvalencia01
Oct 6, 2005 11:57 PM
odecca25
Jul 13, 2005 01:58 PM
