https://cimg9.ibsrv.net/gimg/mitsubi...da36cfa56c.png
https://cimg0.ibsrv.net/gimg/mitsubi...c89ddb247d.png Just throwing this out there, where the pre-96 models aren't OBDII compliant, you don't need the MUT to read them. This company in New Zealand has a software and cable combo that will read codes, and let you activate some of the "actuators" fuel pump, injectors, ABS stuff... https://evoscan.com/ I purchased the 1.3D cable and it works! It's a little touchy, I keep having to unplug the cable to get the software to read. It also does logging! https://evoscan.com/evoscan-gps-obdi...alogging-cable |
@Marksroberts61 Do you happen to know the part number for that wiring harness that connects to the three temp senders on the water pipe? Trying to start tracking one down after discovering some horrific work by PO, and can't seem to locate that in the FSM. Thank you!
Originally Posted by ceharlow
(Post 325905)
Im new to this board, and i'm hear for the tach issue and and ecu question. I have a 95 montero SR 3.5l 24 valve.
I been reading, but have not found a solution so far. First, does a 1995 montero Sr support odb2. I have found 1996 listed as first year in some places and 95 listed in others. I have never got it to talk a single word, and i have tried . even bought a Mitsubishi obd2 meter . i've ohmed the data pin on odb2 plug to ecu, looks good a short, , but no odb2. I am wondering if this is related to issue #2, tach does not work reliably. I replaced the orig tach, with an ebay purchase. the only time it has worked is when its cold out. , Vin # , i'll add as soon as i find it again, it decides what is what if you have the decoder ring thanks in advance for any help chris |
So, no definitive answer on how to check to see if there is an input signal going to a tach that is not working?
Looks like alot of topics were discussed, but no clear answer regarding this. I have a tach that has suddenly stopped and is staying at about the 2k mark. |
I'm a tab late to the party but here anyway. 94 and 95 SR both have the OBDII plugs. Codes can be read with a paper clip. Plug one end into the 1 pin and the other end into the 5 pin. Turn key to start but don't start.
Check engine light will flash Long Flash is tens short flash is ones so 2 long flashes and 4 short flashes would be 24 Vehicle speed sensor and so on. 11 Oxygen sensor fault. 12 Airflow sensor fault. 13 Intake air temp sensor fault. 14 Throttle position sensor (TPS) fault. 15 Idle speed control (ISC) motor position sensor fault. 21 Coolant temp sensor fault. 22 Crankshaft position (CKP) sesnor fault. 23 Camshaft position (CMP) sensor fault. 24 Vehicle speed sensor (VSS) fault. 25 Barometric (BARO) pressure sensor fault. 31 Knock sensor fault. 32 MAP sensor faulty. 36 Ignition timing adjustment signal fault. 39 Oxygen (O2) sensor fault. 41 Injector(s) fault 42 Fuel pump fault. 43 EGR fault. 44 Ignition coil (cylinders #1 & #4) fault. 52 Ignition coil (cylinders #2 & #5) fault. 53 Ignition coil (cylinders #3 & #6) fault. 55 Idle air control (IAC) valve position sensor fault. 59 Rear Oxygen (O2) sesnor fault. 61 Transaxle control module torque reduction signal fault. 62 Variable Induction control (VIC) valve position sensor fault. 71 Traction control (TC) vacuum valve solenoid fault. 72 Traction Control (TC) vent valve solenoid fault. I am curious how the tach situation turned out? Was there any resolution to the problem? |
