95 Tero wont start, and some electronics dont work?
Old Aug 29, 2013 | 03:16 PM
Call-_me-Jordan's Avatar
Default 95 Tero wont start, and some electronics dont work?
I bought this tero as a project. I got a dam good deal on it, and am trying to get it running. It turns over but just wont fire. The dash works, compass, gauges etc, as well as the headlights, but none of the interior lights come one, power locks quit working, power windows stopped. The sun roof still works. I havent got to check it out yet as I have been working. The fuel pump ticks 2-3 times then nothing. Is that the noise it should make? Everyother vehichls I have owned "hum". Thanks.
Old Aug 29, 2013 | 04:32 PM
Akzle's Avatar
is it fuel pump clicking? Or starter? Or fuel solenoid?
Sounds like electrical issue re: lights and windows. (duh).
Out with your multimeter...
Old Aug 29, 2013 | 06:57 PM
Well progress... I checked the fuse box inside, was all good. The one under the hood has the 100a fuse for the alternator missing. The PO rigged it up by bending them over. When I press it together and make contact the interior works, ac comes on, windows etc. But It still wont fire.
DEFIANTLY getting fuel. Disconnected a hose, sprayed it all over the engine bay(lol), we pulled a plug to see if it was firing and you could smell it in the cylinder.
I broke the 60a battery one so its not in its slot.
What are these fuses called? Where can I get these fuses?
Old Aug 29, 2013 | 07:50 PM
Akzle's Avatar
"big f*ckoff fuses"
or, main fuses.
Auto stores, probably any "old fashioned" garage, too.
Did ya get a good bright spark? Or test on a tester?
Otherwise, with fuel and spark, the only other thing is timing. Or compression. Check compression first.
Old Aug 29, 2013 | 07:55 PM
How do I check compression? I dont have a tester.
The way it was killed was the Po took it hunting and left the lights on, and it killed the battery. Got it home, charged it and nothing, got a new battey and nothing, and it hasnt ran since.
Old Aug 29, 2013 | 07:58 PM
It wasnt a good spark, but then again I have those fusses pressed together with pliers. It didnt seem to fire every time.
Old Aug 29, 2013 | 08:01 PM
Akzle's Avatar
a quick and hoary way is to roll up a paper towel and roll, stuff it in the plug hole (tight seal), if it flys out when cranked, you probablx have compression.
If its just been sitting a while, once your fuses are in, hook it up for a jump start.
Crank it a few times with pedal to the floor to clear the cyls, then about 1/4 throttle till it catches.
Old Aug 29, 2013 | 08:19 PM
The battery is defiantly good, I may try stepping back out there and giving it gas to crank. I assume since I could smell gas when trying to crank it with the plug out, the injectors are spraying.
Old Aug 29, 2013 | 08:22 PM
Im betting finding one of these fuses will be a Bch.
Old Aug 29, 2013 | 08:27 PM
Its sat since last year about this time he said. But it had some serious pollen build up, as well as pine straw rotting on the roof... So it might have been longer than that.
