95 Tero wont start, and some electronics dont work?
Old Aug 30, 2013 | 09:11 AM
Call-_me-Jordan's Avatar
Bump, any help?
Old Aug 30, 2013 | 02:06 PM
Akzle's Avatar
no more than yesterday. Did you replace the fuses and try jump starting it?
Old Aug 30, 2013 | 04:12 PM
It has plenty of battery power, but I hooked up the charger to it and tried with that still no go... I am kinda stumped. I tried the giving it gas thing to.
Old Aug 30, 2013 | 06:06 PM
Akzle's Avatar
fresh fuel in the tank?
Old Aug 30, 2013 | 10:10 PM
Mmmmm Idk bout that. assuming its a year old atleast cause of when it was parked, I will pump whats in it out and put some fresh in.
Pulled the ecu to check and see it I could notice any corrosion or signs of defects. Looks A ok to me.
Old Aug 30, 2013 | 10:53 PM
Heres all I am getting... I am acuallty getting a weak spark irregularly... We are holding the plug to see if it sparking..
1995 mitsubishi montero no spark - YouTube
Old Aug 30, 2013 | 11:58 PM
Akzle's Avatar
engines need good spark consistently. Track that down.
Measure everything you can.
Without tracing the ecu pcb, its hard to say, but i wouldnt assume it the problem.
Old Aug 31, 2013 | 07:02 AM
Ecu Pcb? I am trying to track it down.
Old Aug 31, 2013 | 01:46 PM
Akzle's Avatar
ecu=ecu
pcb= printed circuit board. The bit you took a picture of.
What is the ignition system? Cas through ecu? Or a nice simple dizzy an coil?
Old Aug 31, 2013 | 06:09 PM
It has a coil on every cylinder, and has a ignition module. I dont see a distributor where would it be?
