97 montero ls ticking noise 30 sec after cranking
Old Apr 1, 2009 | 06:30 PM
cannonbore's Avatar
Default 97 montero ls ticking noise 30 sec after cranking
wanted see if anybody has this problem. after sitting overnight 40F montero ls cranks up
30 sec later a ticking noise stop after about 30sec usually repeats 3 time at this tem
55f repeats for 2 times,at 65f only once :sound seems to come from back of engine or top or automatic trans
Old Apr 5, 2009 | 12:17 AM
Joel_CA's Avatar
If the ticking is completely in tune with engine RPM- it is likely your hydraulic lifters making noise. If the ticking is at a constant speed independent from engine RPM- it could just be your EVAP purge solenoid - which is normal.
JJ
Old Apr 8, 2009 | 03:11 AM
cannonbore's Avatar
Default thank for info
i going to clean the lash adjusters
Old Apr 8, 2009 | 11:05 AM
Joel_CA's Avatar
There's a TSB from Mitsubishi involving cleaning the lash adjusters/lifters in diesel fuel. Submerge them in diesel fuel and work the plunger inside the oil port up and down with a heavy gauge pin. I haven't tried it myself, but the only other option would be to replace them.
JJ
Old Apr 21, 2009 | 06:12 PM
cannonbore's Avatar
Default problem gone
cleaning took care of the noise but next time i will replace them seem to be some ware on intake lash adjuster.
Old Sep 11, 2013 | 02:28 AM
Carole Corralejo's Avatar
Unhappy lifters making noise "occasionally"
I have an 03 Montero Sport with 177K miles. I just bought it and love it, but I'm worried about the lifters/tappets??? the sound is in line with the engine rpm so I know its in there somewhere. I just don't know enough about the Montero... Has anyone had a similar problem and if so, what did u do to stop it? Is it really dangerous to keep driving it without fixing it? I'm not even sure where the lifters are. I think they are involved somehow with the firing in the valves, right? Please, help if you can...
Thanks!!!
badmitsu
Mar 28, 2014 09:38 PM
carlos.db
Jan 7, 2014 09:37 PM
Ohiohomedoctor
Nov 26, 2012 06:49 PM
einar
Sep 26, 2012 12:24 PM
Scubba.steve
Oct 11, 2008 01:11 PM
