97' montero temp control valve location?
Old Dec 16, 2011 | 11:00 PM
zonarosso's Avatar
Default 97' montero temp control valve location?
My 1997 Montero LS heater control **** will go all the way to the full hot position but springs back to about 3/4 position. Temperature out of vents is weak. The factory manual talks about a heater control valve but does not show its location. I do not see it in the HVAC parts diagrams. Anyone know if this thing is in the engine compartment? I did replace the heater hoses when I did the water pump but can't recall if the hoses hooked to a valve. Thanks for any wisdom- Jim
Old Dec 17, 2011 | 04:52 AM
mxmikie's Avatar
follow the control cable
Old Dec 19, 2011 | 03:30 PM
zonarosso's Avatar
I pulled the radio/ HVAC control trim panel off (2 screws at top of panel, 2 pull to release clips at the bottom), removed the upper and lower brackets that hold the control in. I pulled the control out as far as I could and noticed that the temp control cable was kinked. The cable pushes for higher heat and it was kinked at the control lever. I stuck a long screwdriver in and straightened the cable and now it will push all the way in for max heat. I'll get a cable on order and replace it when I can. Anyone have experience replacing this cable? Wondering if there's anything else I should replace while I'm in there?
Old Dec 19, 2011 | 07:41 PM
mxmikie's Avatar
glad i could help
Old Oct 13, 2012 | 05:43 PM
zonarosso's Avatar
Just as a conclusion, the temp control cable terminates at a lever on top of the plenum behind the glove box. Remove the 2 glove box stops by pushing the end closest to you from the outside of the box and sliding it back. Wiggle and turn to get them out of the slot. The box will now drop down. The cable end is to the right close to the firewall. There is no retaining clip on the cable, it just slides up and off.
mrbo1964
Jul 24, 2014 12:25 AM
ninjaloops916
Mar 10, 2014 09:01 PM
Randys
Aug 12, 2013 06:07 AM
kelsey344
Nov 26, 2007 08:57 PM
popatop
Dec 10, 2004 11:48 PM
