98 montero no spark
Old Jan 24, 2008 | 08:08 PM
rf128's Avatar
Default 98 montero no spark
My montero now has no spark after a alt and battery change. I have pulled the ecu and there is no visable damage or smell. I have checked the connections at the power transmiter and I have power to the fuel pump, I can hear it. The computer sees the injectors fuelinging and has a signal from the crank and cam sensors. I am at the end of the rope. Help if you can.
Regards
Richmond
Old Feb 2, 2008 | 12:15 AM
jgbrules's Avatar
Default RE: 98 montero no spark
hello! did you disconnect the battery when u changed the alternator?? if you didnt the battery wire could have touched something and sparked. i bet you poped one of the fuseible links in the fuse block in the engine compartment. i have seen that happen. if not, some wiring was damaged in that area. good luck!! greg...
Old Mar 8, 2008 | 01:34 AM
xyzik's Avatar
what year? check coil or ignition module
but... fuses is where id start too.
Old Mar 8, 2008 | 09:46 AM
Check all fuses
dcur069
Sep 9, 2010 11:49 PM
djmanm
May 2, 2009 09:04 AM
TRIFILO
Jul 7, 2006 09:40 PM
bcolins
Mar 5, 2005 08:44 PM
Big B
Dec 31, 2004 04:47 PM
