99 Montero rear/trunk door handle replacement?
Old 02-04-2014 | 05:32 PM
corycarbo's Avatar
Default 99 Montero rear/trunk door handle replacement?
I bought a cheap, used 99 montero and need to replace the rear / trunk / hatch door exterior handle, so I can open it from the outside. the white plastic latch that turns the metal thing inside the door is snapped off. It has been a total pain in the but to work on, and before I mess more stuff up, I figured I'd post this thread hoping to get detailed directions. I've been to the junkyards and own a 1st gen swb monty and can say pretty much 100% certain that all monteros have identical rear door exterior handle set ups. Please let me know. thanks!!!!
Old 02-04-2014 | 09:35 PM
navidbe's Avatar
you need to take off the rear insider door panel.
take the outside plastic part off. there is 4 clips, so be easy on it.
once those 2 are off take a small socket, i think its a 10'
take off the 2 bolts, then put everything back on.
Old 05-01-2017 | 12:20 PM
timbertim's Avatar
Default 2002 Montero Rear Door Stuck
I bought WD-40 with the flexible metal straw. This allowed me to insert it through the handle hold above the license plate and spray at multiple angles. I soaked it good and it popped right open. No cutting my tool panel or removing anything. I'm a forester and the Montero has been in continual use since 2002, so I can't imagine one being much dirtier.
I'd sprayed in the hold the day before with a regular WD-40 straw and let sit overnight with no luck. It opened immediately after spraying with the flex straw.
redturboeclipse
07-16-2015 11:56 AM
millerwl71
05-21-2013 08:12 PM
redturboeclipse
15
02-25-2010 06:26 AM
elmiserable
01-20-2009 09:18 PM
elmiserable
01-20-2009 09:13 PM
