99 Montero sport starter not engaging
Old Apr 6, 2021 | 05:35 PM
Joshunt76's Avatar
Default 99 Montero sport starter not engaging
I have a 1999 Mitsubishi Montero sport XLS the starter is not engaging when I turn the switch it just makes it buzzing sound like the stars been magnetized I bought new starter and put it on it did the same thing I bench tested the old starter it works fine what could be the problem
Old Apr 6, 2021 | 11:03 PM
Naeos_Valkarian's Avatar
Check the battery by getting it tested and check the positive and ground connections. The main ground point to the battery is located behind the A/C compressor, you can access it from the driver side fender well pretty easily. Sometimes, these cables can get corroded under the cable insulation and you wouldn't know it. I also wouldn't rule out the battery unless you already tried replacing it to solve the issue.
livetoride20000
11
May 18, 2022 10:01 AM
Vanwilson
Jun 19, 2018 05:57 PM
montyman
11
Jul 30, 2013 11:03 PM
mik543
May 9, 2010 09:36 PM
viking_11
Dec 11, 2008 06:24 PM
