Anti rollover bar ?
Old May 20, 2017 | 11:32 AM
Tdub1966's Avatar
Default Anti rollover bar ?
01 MS LS 4x4 , question: is it necessary to remove or replace this with an adjustable one for more than 3" of lift? Does it limit the lift or bind it?
​​​​​​​Thanks.
Old May 20, 2017 | 10:16 PM
Are you referring to the sway bar? Some of the lift kits come with the sway bar extensions (a little longer connectors). My guess that your old sway bar should work without that in most cases. The only time you may need to disconnect the sway bar is when you do a full on "proper" rock crawling and you want to utilize maximum independent wheel travel.
Gen-8
May 9, 2013 01:59 AM
tchun
Apr 15, 2005 11:10 PM
gforceauto
Mar 5, 2005 12:27 AM
GryphonsClaw
Jan 18, 2005 12:12 PM
