Battery installed backwards :/
Old Jul 21, 2015 | 08:12 PM
Robtaylor's Avatar
Default Battery installed backwards :/
Kind of embarrassing but I accidentally installed my battery backwards. I have replaced the 100amp fuse as well as the fuel relay and control module in the bottom right side of the passenger footwell and the truck is running now. However, the SRS light is constantly on now as well as the check engine light (p1600 code). The truck is very sluggish now on takeoff from a stopped position. Any suggestions?
Old Jul 22, 2015 | 06:30 PM
It is very likely that you had damaged PCM or some other electronic component. The good book says if the code is present - replace PCM. I would first test the throttle actuator and wiring, then if all checks out test and replace PCM. Check ALL fuses, if you are you are lucky, perhaps it is something is simple like that.
Old Jul 22, 2015 | 06:36 PM
Robtaylor's Avatar
Ok thanks I'll try those things. I realize how elementary this mistake is so I appreciate the response.
Old Jul 22, 2015 | 06:55 PM
Robtaylor's Avatar
If I'm able to find a PCM at a junk yard could I just plug it in and use it or does it need to be reconfigured or what? Sorry don't know much about PCM issues. And if I find a TCU as well?
Old Jul 22, 2015 | 11:08 PM
No idea. If it is the same model, theoretically it should be plug and play. One other thing you can try after checking fuses and wiring - unplug the battery for about 15 min. That resets the PCM and if there is a software related glitch, hopefully a hard restart would clear it out. Good luck man.
Old Jul 23, 2015 | 06:41 AM
Robtaylor's Avatar
Ya I've actually disconnected the battery (for 15min +) a couple times trying to reset the PCM. No luck. Think I'm going to try to find both a PCM and also a TCU at the junk yard. Fingers crossed. It just feels like it is lacking horsepower up until third gear,after about 35mph it seems to behave normally. so it makes me think that the PCM and TCU aren't "meshing"? Like somehow it's just not even in first and second gear at all if that's possible. Anyways thanks again for all the advise. Much appreciated.
Old Jul 23, 2015 | 12:26 PM
mxmikie's Avatar
P1600 = Serial Communication Link Malfunction-20
Old Jul 23, 2015 | 01:01 PM
Robtaylor's Avatar
I'm sorry I don't know what that means.
Old Jul 25, 2015 | 10:55 AM
Guyfromhe's Avatar
Basically communication error between modules (PCM/ECM and TCM) or other..
You might want to bring it to your dealer.. If your using a home scanner it probably can't talk to the TCM or SRS computer and is only getting the general codes..
Did you replace the ECU and TCM already?
Old Jul 25, 2015 | 01:39 PM
Robtaylor's Avatar
No I haven't replaced the ecu or the tcu bc I wasn't sure if they need to be reprogrammed first or what? I've done some research and just can't seem to get a clear answer on that so I didn't want to install them and mess anything up any further.
