body lift.....95 montero ls
Old Mar 15, 2009 | 08:50 AM
j wood's Avatar
Question body lift.....95 montero ls
Hello im new to the forum and i am stuck on this issue.....Is it possible to add 35x12.5x15 tires with a 2 inch body lift, cranked torsion bars, and new springs in the back. If it is possible what is the procedure for the body lift??????? PLEASE HELP!!!
Old Mar 20, 2009 | 03:08 AM
lwolfnmonty's Avatar
I have a 94SR, check out 4crawler.com for custom body lifts, I am getting one sometime soon when I also get the money for new tires. My friend used a Hi-Lift Jack to raise the montero high enough, the procedure is a pain in the ***. It is easy to do but takes a long time. you will need to lift the body, unscrew the stock body mounts, place the new mounts in place and replace the old bolts, then lower it. This happens between 8 and 12 times depending on the length of the body. you will probably be 10 or 12 mounts. Once you order the package directions should come with it, I've heard the gentleman that distributes them is very personable, I'm sure you can give him a call to get some definitive directions. I hope this helped.
Old Mar 20, 2009 | 07:35 AM
j wood's Avatar
yea that is what i expected as far as replacing the bolts and putting in the new body mounts....Im just not sure if there are any componets in the car that i need to extend, for example steering shaft or gear shifters, and even the brake lines. Also i need to learn how to raise the bumpers after I do the lift.....and i dont have acess to a welder or anthything like that. anyways thanks for the info!!
Old Mar 20, 2009 | 02:39 PM
you can do it all without raising anything else. The Transfer case and transmission are mounted to the frame, so the ***** will be slightly offset but it is all good. My friend that has already done it got the 2 inch lift and I was able to drive it. The T-Case **** and the Transmission **** seem to be sunk but still work, but you don't NEED to adjust any of these things. Let me look into the steering shaft, i believe he may have modified that but I don't recall the entire procedure.
Most of the stuff is optional, You CAN raise the bumpers, they will be offset with the lift, The gentleman that makes the lifts also offers accessories to lift everything else, no welder necessary at all though.
Old Mar 20, 2009 | 04:39 PM
Alrighty, after asking around and doing some research, 4crawler.com has literally everything for a lift, just check out the site, all the answers are there.
http://www.4crawler.com/4x4/ForSale/...tKit.shtml#Top
Old Mar 20, 2009 | 05:07 PM
j wood's Avatar
thanks brother you been a great help....if anyone else is reading this thread and wants to add some info please do!!!!!!!!
Old Mar 22, 2009 | 10:11 AM
j wood's Avatar
hey did you ever find out about the steering...and also please ask him how he dropped his radiator. thanks
brady1479
Jan 3, 2013 11:51 AM
rob.allee
Feb 29, 2012 10:27 AM
shaneroberts
Feb 1, 2010 03:32 PM
j wood
Mar 14, 2009 11:14 PM
michaeljr5
Jun 6, 2006 04:10 PM
