Brake system pulse noise 2003yr 6G74 3.5L Montero XLS
Old Jun 7, 2016 | 01:26 PM
wilde's Avatar
Default Brake system pulse noise 2003yr 6G74 3.5L Montero XLS
Ever heard antilock brake system make a 4-pulse noise like "urk urk urk urk" that you can feel a little in pedal? I'd like to attach a short & small 4MB video I made but don't know where to put it, lol. It only does it at first press of pedal, about 1/2 second after it's depressed...and every time.
I don't have a brake light on now but sometimes the antilock dummy light will come on and off, or stay for a while.
I don't care if the antilocks don't work because I like all manual old school operation anyway. I know how to drive, lol. But I do want the brakes to always work of course!
It brakes good, straight, quiet and evenly. Fluid is full and doesn't leak out. Seems clean.
Any guesses? Maybe ABS Booster that runs on vacuum...thus the short delay?
There is a small wire on top of the intake plenum that isn't plugged in, but there isn't a male plug anywhere for it to mate with. Took pic of it, but again where do I post pic or video for this site?
Old Jun 7, 2016 | 04:55 PM
larry4406's Avatar
Use the "Go Advanced" tab then select manage attachments to attach files. Observe file size limits.
Old Jun 8, 2016 | 12:41 AM
Most likely it is a failed brake booster accumulator. That will cause the noises when brake pedal applied. Do a quick search on the Montero thread for Brake Booster Accumulator or BBA. I recall there was a thread dealing with this some time ago.
Old Jun 8, 2016 | 01:42 PM
wilde's Avatar
I discovered the noise is the nitrogen filled Brake Accumulator. According to Mitsubishi HQ it's a non-essential part that imposes no safety problems and only symptom is the chirping "urk urk urk urk" noise and MAYBE a firmer than usual pedal sometimes (but I've not noticed that yet).
It IS NOT a "recall" but only a warranty extension for 10 years or 100,000 miles, which ever is first.
So I'm glad. Anything that doesn't require a fix is welcomed!
Old Jun 8, 2016 | 09:03 PM
maco35's Avatar
I replaced mine and the difference in braking power is really noticeable, just remember is a brake booster. There is no need to bleed or reset anything. Genuine Mitsubishi 2002 2006 Montero Hydraulic Brake Accumulator 4630A011 | eBay
wilde
Aug 1, 2020 03:00 AM
shownuff80
Aug 31, 2014 03:40 AM
Raquel
Jan 28, 2010 04:14 PM
jpmontero98
Sep 17, 2007 07:16 PM
trader eds
Jan 12, 2005 09:27 PM
