busted wheel bolts
Old Aug 26, 2009 | 06:50 PM
lovinmrv's Avatar
Default busted wheel bolts
The "highly trained professionals" that put my snow tires on last year broke a couple of wheel studs. I am installing new rotors this weekend, and I figured that it would be a good time to replace the bolts.
Questions:
1. I assume I can buy these things at an auto parts store, correct?
2. How do I get the old ones out of the wheel hub?
Thanks
Old Aug 26, 2009 | 11:33 PM
jwhiteh's Avatar
usually they are pressed in/out. some parts stores may have them. they might have to order. either way, they shouldn't be hard to find.
good luck
Old Aug 27, 2009 | 06:20 PM
jason clipse's Avatar
parts store should have them. and use a hammer to get the old ones out and when u go to put them in. put them back thru the hole then put ur rotor on then tighten a lug nut on the rotor to pull the stud thru the hole. they have grooves that keep them from turning.
Bry13son
Oct 8, 2009 11:26 PM
50ul }{4ck3r
Feb 20, 2007 01:40 PM
dott
Jul 11, 2005 12:14 AM
Defiler
May 11, 2005 08:26 PM
Defiler
May 9, 2005 07:36 PM
