Cam/Crank Sprocket
Old Jul 24, 2014 | 01:17 AM
Garifini's Avatar
Default Cam/Crank Sprocket
I am seeking a Camshaft Sprocket replacement for the passenger side in my 1995 Montero LS 3.0L SOHC 24 Valve. I am unclear what had happened, but the passenger side sprocket suddenly has a chip in the front. I have searched the salvage yards, and have had no luck. I will gladly pay shipping, or if near Portland,Or would gladly travel to you.
I also am having trouble finding info, (besides the FSM, in regards to replacing the Cam/Crank seals,and specifically how to remove them safely. I do not have the special Mitsu tools shown in the FSM, but several other procedures required a certain tool, but had a workaround if one didn't have it. Any links, suggestions, or advice on this matter would be appreciated.
-Gary
Old Jul 24, 2014 | 10:21 AM
mxmikie's Avatar
Old Jul 24, 2014 | 01:47 PM
Akzle's Avatar
oil seals can be pulled out by screwing 2" 8g woodscrews into them and pulling out with vice grips.
Old Aug 12, 2014 | 01:07 AM
Garifini's Avatar
Appreciate the info, and I DO have those items available to remove them.
I am having an issue with the Cam sprocket bolt, I have consulted the Chilton, and searched a few forums, am only afraid of bending the Camshaft itself, or causing harm to the sprocket, and can only guess what the cost would be to replace, with none currently available at the yards in my area.
I did a nice soak with PB Blaster, tapped firmly with a hammer, still not budging. Going to continue to work on it, and welcome any tips, or tricks that have worked for others.
Old Aug 12, 2014 | 02:23 AM
Akzle's Avatar
youd be the hulk to bend a torqued down camshaft.
Are you sure youre turning it the right way?
All the 'tips' you will find by google.
Ive always been able to shift them with a 2ft breaker bar, but if that failed id be into an impact driver.
Old Aug 12, 2014 | 03:00 AM
Garifini's Avatar
Impact Driver it is then, I can get one loaned at a local auto parts store. I do appreciate the feedback Akzle.
Old Aug 23, 2014 | 06:18 AM
Garifini's Avatar
Breaker Bar did the trick, soaked it for a few hours in penetrant first. thanks again Akzle!
chrisdukelow
Apr 18, 2020 02:10 PM
mantis270
Dec 7, 2009 07:26 PM
XFadeLD
Nov 28, 2007 06:52 PM
xslim69
Jan 20, 2007 10:41 PM
oops129
Jan 4, 2006 04:38 AM
